Group: DynoMotion Message: 4764 From: bradodarb Date: 5/4/2012
Subject: AMD 64 on a 32 bit OS
So I re-commissioned a ~3 year old optiplex740 with an AMD64bit proc.
I am running Windows8 32 bit because the 64bit version did not support drivers for my NVidia Quattro.
I was able to install KMotion4.29 with no real issues, but when I plug in my kflop, I don't get the normal blinking pattern, just a quick single pulse and then both on solid.
I also cannot seem to install the FTDI driver. It just shows up as unknown device in the device manager and when I try to manually install the driver it states there is no suitable driver found.
I know Win8 is not supported yet by Dyno, but I'm hoping someone can offer some suggestions.
-Brad Murry
Group: DynoMotion Message: 4767 From: Tom Kerekes Date: 5/4/2012
Subject: Re: AMD 64 on a 32 bit OS
Hi Brad,
The 3 seconds of rapid blinking that KFLOP normally does is performed by the bootloader to check if a Flash recovery is being requested by the PC.  If KFLOP determines that there is no PC connection (by checking the +5V line on the USB connector) it skips that and jumps immediately into the Firmware Version.  So it sounds like your USB connection is not even physically present to get that behavior.  But yet something appears in device manager?
Group: DynoMotion Message: 4768 From: bradodarb Date: 5/4/2012
I verified it is in the Device Manager under [Other Devices] listed as ! Unknown device
I have tried every USB port on this box and it is all the same.
I plugged it into my dev laptop and it still works, so kflop is good.
Incidentally, I have several working USB devices on this machine
(mouse, keyboard, webcam, Skype headset and I have also been able to USB connect to several other micro-controllers with no probs.
Maybe a win8 bug?
-Brad Murry
> Hi Brad,
> Sent: Friday, May 4, 2012 10:30 AM
> Subject: [DynoMotion] AMD 64 on a 32 bit OS
> Thanks,
> -Brad Murry
Group: DynoMotion Message: 4769 From: bradodarb Date: 5/4/2012
In case anyone is interested in trying this or did not know there was a win8 preview-
http://windows.microsoft.com/en-US/windows-8/download
I can say that win 8 is amazing so far. from deep hibernate to actually ready to work is less than 4 seconds.
Oh well, at least we can get a head start on supporting 8!
-Brad Murry
> Maybe a win8 bug?
> -Brad Murry
> > Hi Brad,
> > Thanks,
> > -Brad Murry
Group: DynoMotion Message: 4770 From: Kyryl Perederiy Date: 5/4/2012
Brad,
Have you tried the latest FTDI driver yet? It does not list Win8 as a supported platform, but chances are it may work.
-Kyryl
Sent: Friday, May 04, 2012 12:01 PM
Subject: [DynoMotion] Re: AMD 64 on a 32 bit OS
-Brad Murry
--- In mailto:DynoMotion%40yahoogroups.com, "bradodarb" <bradodarb@...> wrote:
machine
> Maybe a win8 bug?
> -Brad Murry
> --- In
mailto:DynoMotion%40yahoogroups.com, Tom Kerekes <tk@> wrote:
> > Hi Brad,
> > Â
> > Â
> > Â
> > Â
> > From: bradodarb
<bradodarb@>
> > To:
href="mailto:DynoMotion%40yahoogroups.com">mailto:DynoMotion%40yahoogroups.com
> > Subject:
AMD64bit proc.
> > Thanks,
> > -Brad Murry
Group: DynoMotion Message: 4771 From: bradodarb Date: 5/4/2012
Thanks Kyryl,
I just installed that driver as well, and no dice I'm afraid.
When I plug the kflop in, I get a notification in my system tray stating that the usb device malfunctioned and widows was unable to recognize it....
Still works on Win7
-Brad Murry
--- In DynoMotion@yahoogroups.com, "Kyryl Perederiy" <kyrylo@...> wrote:
> Brad,
> http://www.ftdichip.com/Drivers/VCP.htm
> -Kyryl
> From: bradodarb
> -Brad Murry
> --- In mailto:DynoMotion%40yahoogroups.com, "bradodarb" <bradodarb@> wrote:
> > Maybe a win8 bug?
> > -Brad Murry
> > --- In mailto:DynoMotion%40yahoogroups.com, Tom Kerekes <tk@> wrote:
> > > Hi Brad,
> > > Â
> > > Â
> > > Regards
> > > Â
> > > Â
> > > To: mailto:DynoMotion%40yahoogroups.com
> > > Â
> > > Thanks,
> > > -Brad Murry
Group: DynoMotion Message: 4772 From: Tom Kerekes Date: 5/4/2012
Attachments :
Hi Brad,
I'm not sure how deep you want to get into this but W7 (and I assume W8) includes Microsoft Certified Drivers for the FT245RL USB chip that we use.  However we change the VID and PID to be unique to KFLOP so it can be identified as a KFLOP and not something else with the same FTDI chip.  So Windows thinks the device is incompatible.  There is a utility from FTDI that can be used to erase our Configuration so it will then load the standard Windows supplied drivers.  You might try that just to see if the device then installs properly into device manager as an FTDI device.  Our libraries only open FTDI devices that contain the word "KFLOP" or "KMotion" or "Dynomotion" in the driver name so if you do this our Libraries will not recognize the device as a KFLOP.  You might be able to re-name the driver using Device Manager.  Otherwise you could modify our KMotionDLL library to attach to any FTDI device by removing the name restriction.  It's easy to re-flash our configuration into the FTDI chip.  I'll attach the required XML file in case you don't have it.  I wonder if Microsoft in their infinite wisdom now refuses to load non-certified device drivers in W8?
Group: DynoMotion Message: 4773 From: Tom Kerekes Date: 5/4/2012
Opps forgot the link to the FT_PROG Utility
Group: DynoMotion Message: 4774 From: bradodarb Date: 5/4/2012
Hello Tom,
I'd love to get it working as this box will become my primary dev machine for this kind of stuff and I am really loving Win8.
So, I'm down to go deep as long as there is a reasonable amount of guidance.
I looked at the link and noticed many tools, can you specify the correct one?
If the ID's are the problem. I reckon a new device discovery scheme will need to be thought about so as not to corrupt the expected VID/PID.
If that is not the issue, I will need to get at that XML.
-Brad Murry
> http://www.ftdichip.com/Support/Utilities.htm
> From: Tom Kerekes <tk@...>
> Sent: Friday, May 4, 2012 1:58 PM
> Subject: Re: [DynoMotion] Re: AMD 64 on a 32 bit OS
> Hi Brad,
> Sent: Friday, May 4, 2012 1:36 PM
> Thanks Kyryl,
> Still works on Win7
> -Brad Murry
> --- In DynoMotion@yahoogroups.com, "Kyryl Perederiy" <kyrylo@> wrote:
> > Brad,
> > -Kyryl
> > From: bradodarb
> > -Brad Murry
> > > Maybe a win8 bug?
> > > -Brad Murry
> > > > Hi Brad,
> > > > Â
> > > > Â
> > > > Regards
> > > > TK
> > > > Â
> > > > Â
> > > > Â
> > > > Thanks,
> > > > -Brad Murry
Group: DynoMotion Message: 4775 From: Tom Kerekes Date: 5/4/2012
It is the: FT_PROG 2.6.8 - EEPROM Programming Utility
Group: DynoMotion Message: 4776 From: Kyryl Perederiy Date: 5/4/2012
As an alternative I would try to disable Driver Signature Enforcement. You will need to enable Safe Mode to do that. Google "Disable Signature Enforcement" "Windows 8".
-Kyryl
Sent: Friday, May 04, 2012 2:37 PM
Group: DynoMotion Message: 4777 From: bradodarb Date: 5/4/2012
Kyryl,
You are the man!
After a few cycles of downloading the utility from FTDI and running into several dll not found errors- prompting me to try reinstalling the drivers....
I received your suggestion and I am now connected to my Kflop inside win8!
The actual procedure was simple enough::
1) open msconfig
2) check safe mode from boot tab
3) restart
4) plug in Kflop
5) go to device manager
6) update driver
7) open msconfig
8) reset boot options to the original state
9) restart
10) enjoy kflop on windows 8( and with new kflop web+websocket server create CNC metro app!)
Thanks Kyryl for the painless suggestion and Tom for the useful and interesting links.
-Brad Murry
Sent from my Windows 8 PC
> -Kyryl
> From: Tom Kerekes
> Sent: Friday, May 4, 2012 2:24 PM
> Hello Tom,
> Thanks,
> -Brad Murry
> > Â
> > Â
> > From: Tom Kerekes <tk@>
> > To: "mailto:DynoMotion%40yahoogroups.com" <mailto:DynoMotion%40yahoogroups.com>
> > Hi Brad,
> > Â
> > Â
> > Â
> > Thanks Kyryl,
> > Still works on Win7
> > -Brad Murry
> > --- In mailto:DynoMotion%40yahoogroups.com, "Kyryl Perederiy" <kyrylo@> wrote:
> > > Brad,
> > > -Kyryl
> > > From: bradodarb
> > > -Brad Murry
> > > > Maybe a win8 bug?
> > > > -Brad Murry
> > > > > Hi Brad,
> > > > > ÃÆ'‚
> > > > > The 3 seconds of rapid blinking that KFLOP normally does is performed by the bootloader to check if a Flash recovery is being requested by the PC.ÃÆ'‚ If KFLOP determines that there is no PC connection (by checking the +5V line on the USB connector) it skips that and jumps immediately into the Firmware Version.ÃÆ'‚ So it sounds like your USB connection is not even physically present to get that behavior.ÃÆ'‚ But yet something appears in device manager?
> > > > > ÃÆ'‚
> > > > > Regards
> > > > > TK
> > > > > ÃÆ'‚
> > > > > ÃÆ'‚
> > > > > ÃÆ'‚
> > > > > Thanks,
> > > > > -Brad Murry
Group: DynoMotion Message: 4840 From: bradodarb Date: 5/8/2012
Update::
It seems the steps listed do yield a usable system... UNITL you disconnect the Kflop.
I may have to look again at those utilities to find a more permanent solution.
Tom - how would you like to see this happen to get ready for win8?
-Brad
> Kyryl,
> You are the man!
> 1) open msconfig
> 3) restart
> 4) plug in Kflop
> 6) update driver
> 7) open msconfig
> 9) restart
> -Brad Murry
> > -Kyryl
> > From: Tom Kerekes
> > Hello Tom,
> > Thanks,
> > -Brad Murry
> > > Â
> > > Â
> > > Hi Brad,
> > > Â
> > > Â
> > > Regards
> > > Â
> > > Thanks Kyryl,
> > > Still works on Win7
> > > -Brad Murry
> > > > Brad,
> > > > -Kyryl
> > > > From: bradodarb
> > > > -Brad Murry
> > > > > Maybe a win8 bug?
> > > > > -Brad Murry
> > > > > > Hi Brad,
> > > > > > ÃÆ'‚
> > > > > > ÃÆ'‚
> > > > > > Regards
> > > > > > TK
> > > > > > ÃÆ'‚
> > > > > > ÃÆ'‚
> > > > > > ÃÆ'‚
> > > > > > Thanks,
> > > > > > -Brad Murry
Group: DynoMotion Message: 4841 From: bradodarb Date: 5/8/2012
Hello Tom,
After a little research, I do not think the modified PID and VID are the issue, I think it is just down to the driver needing to be signed.
-Brad
> Update::
> -Brad
> > Kyryl,
> > You are the man!
> > 1) open msconfig
> > 3) restart
> > 4) plug in Kflop
> > 6) update driver
> > 7) open msconfig
> > 9) restart
> > -Brad Murry
> > > -Kyryl
> > > From: Tom Kerekes
> > > Hello Tom,
> > > Thanks,
> > > -Brad Murry
> > > > Â
> > > > Â
> > > > TK
> > > > Hi Brad,
> > > > Â
> > > > Â
> > > > Regards
> > > > TK
> > > > Â
> > > > Thanks Kyryl,
> > > > Still works on Win7
> > > > -Brad Murry
> > > > > Brad,
> > > > > -Kyryl
> > > > > From: bradodarb
> > > > > -Brad Murry
> > > > > > Maybe a win8 bug?
> > > > > > -Brad Murry
> > > > > > > Hi Brad,
> > > > > > > ÃÆ'‚
> > > > > > > ÃÆ'‚
> > > > > > > Regards
> > > > > > > TK
> > > > > > > ÃÆ'‚
> > > > > > > ÃÆ'‚
> > > > > > > ÃÆ'‚
> > > > > > > Thanks,
> > > > > > > -Brad Murry
Group: DynoMotion Message: 4842 From: bradodarb Date: 5/8/2012
Hello Tom,
Can you make this happen?
http://technet.microsoft.com/en-us/query/ff544865
Let me know if I can be of any assistance.
-Brad Murry
> Hello Tom,
> -Brad
> > Update::
> > -Brad
> > > Kyryl,
> > > You are the man!
> > > 1) open msconfig
> > > 3) restart
> > > 4) plug in Kflop
> > > 6) update driver
> > > 7) open msconfig
> > > 9) restart
> > > -Brad Murry
> > > > -Kyryl
> > > > From: Tom Kerekes
> > > > TK
> > > > Hello Tom,
> > > > Thanks,
> > > > -Brad Murry
> > > > > Â
> > > > > Â
> > > > > TK
> > > > > Hi Brad,
> > > > > Â
> > > > > Â
> > > > > Regards
> > > > > TK
> > > > > Â
> > > > > Thanks Kyryl,
> > > > > Still works on Win7
> > > > > -Brad Murry
> > > > > > Brad,
> > > > > > -Kyryl
> > > > > > From: bradodarb
> > > > > > -Brad Murry
> > > > > > > Maybe a win8 bug?
> > > > > > > -Brad Murry
> > > > > > > > Hi Brad,
> > > > > > > > ÃÆ'‚
> > > > > > > > ÃÆ'‚
> > > > > > > > Regards
> > > > > > > > TK
> > > > > > > > ÃÆ'‚
> > > > > > > > ÃÆ'‚
> > > > > > > > ÃÆ'‚
> > > > > > > > Thanks,
> > > > > > > > -Brad Murry
Group: DynoMotion Message: 4843 From: bradodarb Date: 5/8/2012
Hello Tom,
-Brad Murry
> Hello Tom,
> -Brad
> > Update::
> > -Brad
> > > Kyryl,
> > > You are the man!
> > > 1) open msconfig
> > > 3) restart
> > > 4) plug in Kflop
> > > 6) update driver
> > > 7) open msconfig
> > > 9) restart
> > > -Brad Murry
> > > > -Kyryl
> > > > From: Tom Kerekes
> > > > TK
> > > > Hello Tom,
> > > > Thanks,
> > > > -Brad Murry
> > > > > Â
> > > > > Â
> > > > > TK
> > > > > Hi Brad,
> > > > > Â
> > > > > Â
> > > > > Regards
> > > > > TK
> > > > > Â
> > > > > Thanks Kyryl,
> > > > > Still works on Win7
> > > > > -Brad Murry
> > > > > > Brad,
> > > > > > -Kyryl
> > > > > > From: bradodarb
> > > > > > -Brad Murry
> > > > > > > Maybe a win8 bug?
> > > > > > > -Brad Murry
> > > > > > > > Hi Brad,
> > > > > > > > ÃÆ'‚
> > > > > > > > ÃÆ'‚
> > > > > > > > Regards
> > > > > > > > TK
> > > > > > > > ÃÆ'‚
> > > > > > > > ÃÆ'‚
> > > > > > > > ÃÆ'‚
> > > > > > > > Thanks,
> > > > > > > > -Brad Murry
Group: DynoMotion Message: 4851 From: Tom Kerekes Date: 5/8/2012
Hi Brad,
I did load the W8 preview on my VIAO dual core laptop and it runs, but haven't had time to experiment yet.
Yeah you could explain what we need to do :}
All we really do is take the USB Driver files from FTDI (which are actually MS Certified) and make a new .inf file to install them.  They actually provide a utility to help with this.  MS then declares those to be the un-certified.
Group: DynoMotion Message: 4863 From: Tom Kerekes Date: 5/8/2012
Hi Brad,
BTW I upgraded a W7 system with KFLOP already installed to W8 and it seems to work fine.
Under Device Manager under the Device Properties for Digital Signer it says Not Digitally Signed.
Group: DynoMotion Message: 4876 From: bradodarb Date: 5/9/2012
Hello Tom,
My system was a fresh install from USB boot.
Sounds like a nice methodology is built in to 'grandfather in' unsigned drivers that existed on the system prior to upgrade.
-Brad Murry
> Hi Brad,
> Sent: Tuesday, May 8, 2012 10:20 AM
> Hello Tom,
> -Brad Murry
> > Hello Tom,
> > -Brad
> > > Update::
> > > -Brad
> > > > Kyryl,
> > > > You are the man!
> > > > 1) open msconfig
> > > > 3) restart
> > > > 4) plug in Kflop
> > > > 6) update driver
> > > > 7) open msconfig
> > > > 9) restart
> > > > -Brad Murry
> > > > > -Kyryl
> > > > > From: Tom Kerekes
> > > > > TK
> > > > > Hello Tom,
> > > > > Thanks,
> > > > > -Brad Murry
> > > > > > Â
> > > > > > Â
> > > > > > TK
> > > > > > Hi Brad,
> > > > > > Â
> > > > > > Â
> > > > > > Regards
> > > > > > TK
> > > > > > Â
> > > > > > Thanks Kyryl,
> > > > > > Still works on Win7
> > > > > > -Brad Murry
> > > > > > > Brad,
> > > > > > > -Kyryl
> > > > > > > From: bradodarb
> > > > > > > -Brad Murry
> > > > > > > > Maybe a win8 bug?
> > > > > > > > -Brad Murry
> > > > > > > > > Hi Brad,
> > > > > > > > > ÃÆ'Æ'‚
> > > > > > > > > The 3 seconds of rapid blinking that KFLOP normally does is performed by the bootloader to check if a Flash recovery is being requested by the PC.ÃÆ'Æ'‚ If KFLOP determines that there is no PC connection (by checking the +5V line on the USB connector) it skips that and jumps immediately into the Firmware Version.ÃÆ'Æ'‚ So it sounds like your USB connection is not even physically present to get that behavior.ÃÆ'Æ'‚ But yet something appears in device manager?
> > > > > > > > > ÃÆ'Æ'‚
> > > > > > > > > Regards
> > > > > > > > > TK
> > > > > > > > > ÃÆ'Æ'‚
> > > > > > > > > ÃÆ'Æ'‚
> > > > > > > > > ÃÆ'Æ'‚
> > > > > > > > > Thanks,
> > > > > > > > > -Brad Murry
Group: DynoMotion Message: 4877 From: bradodarb Date: 5/9/2012
Hello Tom,
Also, even on Win7 you need to jump through some hoops to get the driver installed(admin rights + manual driver install with lots of warnings).
I'm pretty sure signing the driver will eliminate that whole side of it.
An overview is here::
http://technet.microsoft.com/en-us/query/ff549724
And the process is fairly well defined here::
http://msdn.microsoft.com/en-us/windows/hardware/gg487332.aspx
Looks like the first step is to obtain a valid certificate from a third party.
-Brad Murry
> Hello Tom,
> -Brad Murry
> > Hi Brad,
> > Hello Tom,
> > -Brad Murry
> > > Hello Tom,
> > > -Brad
> > > > Update::
> > > > -Brad
> > > > > Kyryl,
> > > > > You are the man!
> > > > > 1) open msconfig
> > > > > 3) restart
> > > > > 4) plug in Kflop
> > > > > 6) update driver
> > > > > 7) open msconfig
> > > > > 9) restart
> > > > > -Brad Murry
> > > > > > -Kyryl
> > > > > > From: Tom Kerekes
> > > > > > TK
> > > > > > Hello Tom,
> > > > > > Thanks,
> > > > > > -Brad Murry
> > > > > > > Â
> > > > > > > Â
> > > > > > > TK
> > > > > > > Hi Brad,
> > > > > > > Â
> > > > > > > Â
> > > > > > > Regards
> > > > > > > TK
> > > > > > > Â
> > > > > > > Thanks Kyryl,
> > > > > > > Still works on Win7
> > > > > > > -Brad Murry
> > > > > > > > Brad,
> > > > > > > > -Kyryl
> > > > > > > > From: bradodarb
> > > > > > > > -Brad Murry
> > > > > > > > > Maybe a win8 bug?
> > > > > > > > > -Brad Murry
> > > > > > > > > > Hi Brad,
> > > > > > > > > > ÃÆ'Æ'‚
> > > > > > > > > > ÃÆ'Æ'‚
> > > > > > > > > > Regards
> > > > > > > > > > TK
> > > > > > > > > > ÃÆ'Æ'‚
> > > > > > > > > > ÃÆ'Æ'‚
> > > > > > > > > > ÃÆ'Æ'‚
> > > > > > > > > > Thanks,
> > > > > > > > > > -Brad Murry
